Component: Temperature Infrared (Grove 101020062) (Environmental)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temperature Infrared (Grove 101020062) component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
Please click here to download the component source project: FC_Comp_Source_GroveIRTemp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GroveIRTemp.fcfx
MeasureObjectTemp
MeasureObjectTemp
Measures the temperature of the targetted object
- FLOAT Return
MeasureSurTemp
MeasureSurTemp
Measures the surrounding ambient temperature,
- FLOAT Return
Ambient Pin (SUR)
Object Pin (OBJ)
ADC Properties
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Advanced Settings
Temperature Calibration
Ambient temperature calibration value
Temperature Range
Map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and object distance is 9CM.
Offset Voltage
Voltage of mid level voltage after 5-10 mins to bring the sensor to ambient.
Number of Samples
Number of samples to take to average out each reading. Default 10.
