Component: MIAC Basic (MIAC: Addon Modules)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Author
Category MIAC: Addon Modules
MIAC Basic component
Basic Addon expansion module for MIAC System
Please click here to download the component source project: FC_Comp_Source_ma_basic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ma_basic.fcfx
AnalogInput
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
DigitalInput
DigitalInput
Read the value of a terminal
- BYTE Terminal
DigitalOutput
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
Initialize
Initialize
Forces a software reset on the module
LED_Control
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Init
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_Message
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_PushData
- BYTE Data
MIAC_Module_SetData
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
PWM_Disable
PWM_Disable
Disable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
PWM_Enable
PWM_Enable
Enable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
PWM_SetDuty
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
- BYTE Duty
Duty cycle (8 bit value)
Module Type
Module Address
PWM
Period Overflow
Prescaler
Frequency (KHz)
Period (uS)
