Component: Colour Sensor (TCS3200) (Light)
| Version | 1.1 |
| Category | Light |
Colour Sensor component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
Please click here to download the component source project: FC_Comp_Source_Colour_TCS3200.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Colour_TCS3200.fcfx
GetFrequency
| GetFrequency | |
| Samples and returns the sensor output frequency (Hz) | |
| Initialise the sensor configuration as set by the component properties | |
SetConfig
| SetConfig | |
| Sends the config data byte to the sensor using clock and data pins | |
| Data | |
SetFilter
| SetFilter | |
| Dynamically change the sensor filter to RGB or W. Red = 0 Green = 1 Blue = 2 White = 3 | |
| FilterColour | |
| Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3 | |
SetFrequencyRange
| SetFrequencyRange | |
| Dynamically change the sensor output frequency range to a new setting | |
| Freq | |
| Percentage range (2,20,100) | |
SetLEDOff
| SetLEDOff | |
| Turn off the White LEDs | |
SetLEDOn
| SetLEDOn | |
| Turn on the White LEDs | |
