Component: Current Sensor (ILA260) (Electrical)
Category Electrical
Current Sensor (ILA260) component
The INA260 provides voltage current and power monitoring via a digital I2C interface.
CheckAlert
CheckAlert
Checks to see if a conversion is ready or if a limit has been hit. Returns 1 for a conversion ready.
- BOOL Return
Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified.
- BOOL Return
ReadCurrent
ReadCurrent
Reads the current as a floating point value in mA.
- FLOAT Return
ReadPower
ReadPower
Reads the power as a floating point value in mW.
- FLOAT Return
ReadVoltage
ReadVoltage
Reads the voltage as a floating point value in mV.
- FLOAT Return
SetAlertLimit
SetAlertLimit
Sets the Alert limit in the format required.
- FLOAT Limit
Limit in mA, mV or mW
- BYTE Units
0=mA, 1=mV, 2=mW
SetAveragingCount
SetAveragingCount
Sets the number of samples for each averaged sample.
- BYTE Count
Range: 0-7 - 0=1, 1=4, 2=16, 3=64, 4=128, 5=256, 6=512, 7=1024
SetConversionTime
SetConversionTime
Sets the amount of time required for each conversion.
- BYTE Time
Range: 0-7 - 0=140uS, 1=204uS, 2=332uS, 3=588uS, 4=1.1mS, 5=2.116ms, 6=4.156mS, 7=8.244mS
SetMaskedAlerts
SetMaskedAlerts
Sets the alert conditions that will be shown on the alert pin
- BYTE AlertMask
0=None, bit0=ConversionReady, bit1=OverP, bit2=UnderV, bit3=OverV, bit4=UnderI, bit5=OverI
SetMode
SetMode
Sets the mode of the sensor and therefore the amount of power consumed by the sensor.
- BYTE Mode
0=Shutdown, 3=Triggered, 7=Continuous
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Settings
Address A0
Address A1
Default Mode
Sets the default mode of the sensor on initialise. Can be overridden using the SetMode macro.
Conversion Time
Sets the default conversion time set during initialise. Can be overridden using the SetConversionTime macro.
Averaging Count
Sets the number of samples used for each averaging period. Can be overridden using the SetAveragingCount macro.
Alert Polarity
Alert Latch
Masked Alerts
Conversion Ready
Alert Limit
Alert Value
API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Current_and_Power_Sensor_INA260.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_and_Power_Sensor_INA260.fcfx
