Component: EEPROM (DS28E07) (EEPROM)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author MatrixTSL
Category EEPROM
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_EEPROM_DS28E07.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM_DS28E07.fcfx
AddressNextDevice
AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetByte
GetByte
Reads a single byte from the selected address.
- UINT Address
Address of the value to read
GetByteArray
GetByteArray
Reads an array of bytes starting from the selected address.
- UINT Address
Starting address of the first value to read
- BYTE Data
Byte array to store incoming data
- UINT Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
GetFloat
GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
- INT Address
The starting byte address
- BOOL MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
- FLOAT Return
GetInt
GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
- INT Address
- BOOL MSBFirst
GetLong
GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
- INT Address
- BOOL MSBFirst
- ULONG Return
GetSerialString
GetSerialString
Gets the Serial String for the current addressed device.
- STRING Return
GetString
GetString
Gets a string from the specified start address.
- UINT Address
Address of the first data byte
- BYTE MaxLength
Maximum number of bytes in the string, also includes null termination byte
- STRING Return
Configures each matching sensor on the bus with the specified conversion bits.
SetByte
SetByte
Writes a single byte to the EE memory.
- UINT Address
Address of the value to write
- BYTE Data
SetByteArray
SetByteArray
Writes an array of bytes to the EE memory.
- UINT Address
Starting address of the first value to write
- BYTE Data
- BYTE Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetFloat
SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
- UINT Address
- FLOAT Value
Floating point value to write
- BOOL MSBFirst
SetInt
SetInt
Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
- UINT Address
- UINT Value
16-bit value to write
- BOOL MSBFirst
SetLong
SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
- UINT Address
- ULONG Value
32-bit value to write
- BOOL MSBFirst
SetString
SetString
Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
- UINT Address
- STRING Value
Data string to write
One Wire Component
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
Simulate Comms
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Panel Simulation
Number EE Devices
Sens the number of sensors we can communicate with during simulation
Serial 0
Serial number for simulated one wire device
