Component: Buzzer (Audio Output)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Audio Output
Buzzer component
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation. To actually drive a buzzer you would have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here to download the component source project: FC_Comp_Source_Buzzer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Buzzer.fcfx
Depending on your Buzzer you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
A basic buzzer example using all the buzzer functions.
It should be noted that if you have a single BuzzerOn component with no loop, the buzzer sound will stop when the simulation stops.
The pin will remain high.
While the buzzer is on, the simulation tone is not continuous, it rapidly pulses, the pin will remain high.
That is not a bug with the component
Basic Buzzer Example
BuzzerBeep
BuzzerBeep
Switches the buzzer on and off automatically to allow for a series of beeps
- UINT OnTime
Length of time in ms the buzzer will remain on
- UINT OffTime
Length of time in ms the buzzer will remain off
- BYTE NumberLoops
Number of times to repeat the sequence. Range 1-255
BuzzerOff
BuzzerOff
Switch Off the Buzzer
BuzzerOn
BuzzerOn
Switch On the Buzzer
BuzzerOnDelay
BuzzerOnDelay
Switch the Buzzer on for a fixed amount of time
- UINT Time
Time in milliseconds to keep the buzzer on
Output Pin
Pin used to drive the output to the buzzer
Polarity
Controls the pin state required to switch the buzzer on.
Buzzer Frequency
Frequency of the buzzer in Hz to drive the simulation
