Component: Current Sensor (ACS7xx) (Electrical)
Author medelec35
Category Electrical
Current Sensor (ACS7xx) component
ACS7XX range of +/- 5, 20, 30, 50, 100, 150 & 200A current sensors
A simple example shows how to use a ASC712 to measure current range of +/- 5A. The component type can be changed within its properties.
ACS712 example
Current
Current
Current reading in amps
- FLOAT Return
VoltgeADC
VoltgeADC
Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
- FLOAT Return
Device
Type
VDD
For improved accuracy, measure the voltage across the supply of the current sensor, then enter that as VDD voltage.
Offset current adjust (Amps)
Offset current adjusts the curent output when comparing to a current monitor. For example current from the componet shows 2.0 Amps and curent monitor shows 1.5 Amps. For the current offset enter -0.5
VRef option
Conversion speed
Acquisition cycles
Average Loop (1 - 255)
The more higher the value, the more stable and accurate result would be. Results will take longer. Try 200
Offset Voltage
The voltage value when no cureent is flowing This is normally 2.5V for bidirectional and 0V for Unidirectional
Bit Depth
Sensitivity
Component sensitivity x10
Please click here to download the component source project: FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
