Component: MQTT Client ( Comms)
Author MatrixTSL
Version 0.1
Category Comms
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak via WebSockets. Allows IoT type data to be published and read back.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_MQTT.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_MQTT.fcsx
Please note this component currently only supports Web Sockets and must be connected to the Web Socket enabled port of the broker.
Temperature and Humidity
Here is an example MQTT project showing how to collect data from a remote device using MQTT.
The heater and fan buttons have onclick event macros that encode JSON data and send to a MQTT topic named mtx_demo_switchdata.
The OnMqttConnected event macro subscribes to MQTT topics named mtx_demo_sensedata which contains the embdeeded temperature and humidity data and mtx_demo_switchdata which contains the current fan and heater output states.
MQTT Web App Client Demo
Here is a corresponding ESP32 project that samples a temperature and humidity sensor and sends the data.
MQTT ESP32 Client Demo
Temperature and Humidity HTTPS
Here is the temperature and humidity example again but this time set to use HTTPS so that it can be ran from a enabled HTTPS webserver.
MQTT Web App Client HTTPS Demo
An example of this can be seen via the URL: https://flowcode.co.uk/example/index.htm
Connect
Connect
Connects to the MQTT server (returns false if already connected)
- BOOL Return
Disconnect
Disconnect
Disconnect from the MQTT server (returns false if client is already disconnected)
- BOOL Return
GetClientId
GetClientId
Returns the unique identifier currently used when communicating with the server.
- STRING Return
Publish
Publish
Publish a message to the MQTT server (returns false in the client is not connected)
- STRING Topic
The name of the topic for the message
- STRING Message
The message to publish
- BYTE QoS
The quality of service used to deliver the message (0, 1 or 2)
- BOOL Retained
If true. the message is to be retained by the server and delivered to future subscribers as well as current ones
- BOOL Return
PublishBuffer
PublishBuffer
Publish an array of bytes to the MQTT server (returns false in the client is not connected)
- STRING Topic
- HANDLE Buffer
The message to publish (as an array buffer)
- BYTE QoS
- BOOL Retained
- BOOL Return
Subscribe
Subscribe
Subscribe to messages from the MQTT server (returns false in the client is not connected)
- STRING Topic
A filter for the topic name(s) to receive
- BYTE QoS
- BYTE Timeout
The number of seconds to wait before assuming this operation failed
- BOOL Return
Unsubscribe
Unsubscribe
Unsubscribe from messages from the MQTT server (returns false in the client is not connected)
- STRING Topic
A filter for the topic name(s) to stop receiving
- BYTE Timeout
- BOOL Return
Host
The address of the messaging server, as a fully qualified WebSocket URI, as a DNS name or dotted decimal IP address
Port
The port number to connect to
Directory
An optional subdirectory off the host address (e.g. "/mqtt")
Client Id
A unique identifier for this client, between 1 and 23 characters in length
Advanced
Use SSL
Use a secure (SSL) connection
Use authentication
Use authentication
Connection timeout
If connection has not succeeded within this time (in seconds), it is deemed to have failed
Keep Alive Interval
The server will disconnect this client if there is no activity for this time period (in seconds)
Clean Session
If true, a non-persistent connection is created, meaning subscription information and undelivered messages are not retained when this connection ends
Reconnect
If true, this client will attempt to reconnect to the server if the connection is lost
Send LWT
Send a 'Last Will and Testament' message if unexpected disconnection occurs
MQTT Version
Which version of MQTT to use
Debug
Determines if additional logging information is sent to the JavaScript console
Callbacks
OnSuccess
Called when an MQTT operation is successful
OnFailure
Called when an MQTT operation is unsuccessful
OnConnected
Called when an MQTT connection is successfully made to the server
OnConnectionLost
Called when an MQTT connection has been lost
OnMessageDelivered
Called when an MQTT message has been delivered
OnMessageArrived
Called when an MQTT message has arrived at this client
