Component: MIAC Serial (MIAC: Addon Modules)
Author
Category MIAC: Addon Modules
MIAC Serial component
Serial Addon expansion module for MIAC System
FREE
UART_ReceiveChar
- BYTE Timeout
FAT_OpenFile
- STRING Filename
PWM_Enable
Enable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
MI2C_Send_Byte_Transaction
[[File:]] - Device_ID
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Data
SERIAL_ReceiveChar
- BYTE Timeout
FAT_Init
SERIAL_SendChar
- UINT Character
SPI_Uninit
MI2C_Stop
UART_SendString
- STRING Text
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
FAT_ScanCurrentFolder
- UINT idx
- BYTE type
Scan type
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
SPI_Init
FAT_AppendStringToFile
- STRING Text
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
MI2C_Restart
FAT_OpenFolder
- STRING Folder
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
SPI_Get_Char
[[File:]] - Return
UART_Initialize
FAT_MoveToNextFileSector
- BYTE force
force next sector
FAT_ReadByteFromScan
- UINT idx
SPI_Send_Char
[[File:]] - Char
FAT_ReadFileLength
MI2C_Transmit_Byte
[[File:]] - Data
[[File:]] - Return
FAT_CreateFile
- STRING Filename
MIAC_Module_PushData
- BYTE Data
MI2C_Receive_Byte
[[File:]] - Last
MI2C_Init
PWM_Disable
Disable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
SERIAL_ReceiveString
- BYTE Timeout
- BYTE NumBytes
- STRING Return
FAT_WriteFileSector
SERIAL_SendString
- STRING Text
MI2C_Receive_Byte_Transaction
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Return
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
FAT_ReadByteFromBuffer
- UINT address
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
FAT_ReadFileSector
FAT_WriteByteToBuffer
- UINT address
- BYTE data
SERIAL_Initialize
FAT_DeleteFile
- STRING Filename
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
Initialize
Forces a software reset on the module
UART_ReceiveString
- BYTE Timeout
- BYTE NumBytes
- STRING Return
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
- BYTE Duty
Duty cycle (8 bit value)
MI2C_Start
DigitalInput
Read the value of a terminal
- BYTE Terminal
UART_SendChar
- UINT Character
Module Type
Module Address
Period Overflow
Prescaler
Frequency (KHz)
Period (uS)
Data Bits
Return Type
Echo
Flow Control
Rate
Prescale option selector
Clock Polarity
Clock Phase
Sample Point
Data bit read sample point
Baud Select
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Data Bits
Return Type
Echo
Flow Control
Simulations
