Component: XML JSON Parser (Runtime Tools)
Author MatrixTSL
Category Runtime Tools
XML JSON Parser component
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
Please click here to download the component source project: FC_Comp_Source_XMLParser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_XMLParser.fcfx
AddObject
AddObject
Adds a tag at the selected location. Use the GetRootHandle and runtime API Tree functions . Returns the handle of the new object.
- HANDLE ParentObject
The Object Handle to store the new tag inside
- STRING Tag
Name of the object
- STRING Data
data for the object (optional)
- HANDLE Return
BuildJSONString
BuildJSONString
Generate a JSON string based on the current objects inside the component.
- STRING Return
BuildXMLString
BuildXMLString
Generate a XML string based on the current objects inside the component.
- STRING Return
ClearObjects
ClearObjects
Deletes all object data ready for fresh input
DeleteObject
DeleteObject
Deletes a selected tag object.
- HANDLE Object
Handle to the object
- BOOL Return
FindNextObject
FindNextObject
Finds the next instance of an object following a GetObject* call. Returns the first matching path from the last search. Returns 0 if the path was not found.
- STRING SubObjPath
e.g. "item.title"
- HANDLE Return
FindNextObjectString
Searches for and then collects the data string from the specified path. Returns the first matching path from the last search
- STRING SubObjPath
e.g. "item.title"
- STRING Return
FindObject
FindObject
Finds the first instance of an object. Returns the first matching path from the root. Returns 0 if the path was not found.
- STRING ObjPath
e.g. "rss.channel.title"
- HANDLE Return
FindObjectString
FindObjectString
Searches for and then collects the data string from the specified path. Returns the first matching path from the root.
- STRING ObjPath
- STRING Return
GetObjectString
GetObjectString
Collects the data string from the specified object.
- HANDLE Object
- STRING Return
GetObjectTag
GetObjectTag
Collects the tag string from the specified object.
- HANDLE Object
- STRING Return
GetRootHandle
GetRootHandle
Allows for user to step through the objects manually using the inbuilt runtime api calls.
- HANDLE Return
ParseJSONDataString
ParseJSONDataString
Parses JSON formatted data in a piecemeal format as and when file data is available. Creates objects to store the contents of the JSON
- STRING Data
JSON Data string, can be a chunk of a file at a time
- UINT Length
Number of Bytes to process
ParseXMLDataString
ParseXMLDataString
Parses XML formatted data in a piecemeal format as and when file data is available. Creates objects to store the contents of the XML.
- STRING Data
XML Data string, can be a chunk of a file at a time
- UINT Length
Number of bytes to process
SetObjectString
SetObjectString
Sets the data string of an existing object.
- HANDLE Object
- STRING Data
SetObjectTag
SetObjectTag
Sets the tag name of an existing object.
- HANDLE Object
- STRING Tag
