| Author
Matrix Ltd
| Version
1.5
| Category
Buffer
Circular Buffer (Float) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific floating point values.
FlushBuffer
FlushBuffer
| Clears the contents of the buffer and re-initialises the index locations.
GetData
GetData
| Reads the next available 32-bit floating point value from the circular buffer, Returns the default value if the buffer is empty.
- FLOAT
GetIndexedValue
GetIndexedValue
| Gets the value of a single 32-bit floating point value at a known location in the buffer. Leaves the buffer contents and pointers untouched.
- UINT
address
- FLOAT
GetNumberValues
GetNumberValues
| Returns the number of valid 16-bit data values currently stored inside the buffer.
- UINT
GetSize
GetSize
| Returns the number of 16-bit values that can be stored in the buffer. Either in total or the number of values remaining based on Mode.
- BOOL
Mode
| 0=TotalBufferSize, 1=BufferFreeSpace
- UINT
LookForValues
LookForValues
| Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
- FLOAT
Values
- BYTE
NumValues
| The number of values you wish to try and match
- BYTE
RemoveContent
| 0=Leave data alone, 1=Remove data from buffer
- BYTE
ResetFind
| 0=Continue the find from the last operation, 1=Start again
- BYTE
PeekData
PeekData
| Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty.
- FLOAT
PutData
PutData
| Add a 32-bit floating point value to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
- FLOAT
Data
- BYTE
WaitForValues
WaitForValues
| Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
- FLOAT
Values
- BYTE
NumValues
| Number of values to try and look for
- BYTE
RemoveContent
| 0=Leave the buffer contents untouched, 1=Remove values as you go
- UINT
Timeout
| Max amount of time to wait in milliseconds before returning 0=WaitForever
- BYTE
Buffer Size
| Sets the number of byte elements inside the circular buffer.
Storage Type
| When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Memory Type
Default Return Data
| Specifies the value returned by the receive function when there is no data held in the buffer
Please click here to download the component source project: FC_Comp_Source_CircularBufferFloat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CircularBufferFloat.fcfx
