Component: API UART Dummy (API Slave Devices)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 2.0
Category API Slave Devices
API UART Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_API_UART_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_UART_Dummy.fcfx
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-19
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTBaud
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
UARTCheckRX
- BYTE Channel
UARTInitialise
UARTInitialise
- BYTE Channel
UARTReceive
UARTReceive
- BYTE Channel
UARTSend
UARTSend
- BYTE Channel
- BYTE Data
