Component: DDS DAC Synth (AD9851) (Analog Output)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Analog Output
DDS DAC Synth (AD9851) component
Digitally programmable frequency synthesiser module.
Sets up the pin connections to the module, ready for communications
Reset
Reset
Resets the DDS module
SweepTone
SweepTone
This function will generate Frequency Sweep signal
- ULONG Frequency
Center frequency in Hz
- ULONG Deviation
Sweep deviation in Hz
- LONG Step
Step or Frequency Resolution in Hz + or -
- UINT Delay_us
Time in micro seconds between each step
WriteFrequency
WriteFrequency
This function will write the desired frequency into AD9851 and generate SINE WAVE The 6 x Clock multiplier is always enabled (assume that you are using 30 MHz clock) Frequency range: DC - 90 MHz (DC - 60 MHz in practice)
- ULONG Frequency
Reset
Data
FQ_UD
CLK
Please click here to download the component source project: FC_Comp_Source_AD9851_DDS_DAC_Frequency_Synth.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AD9851_DDS_DAC_Frequency_Synth.fcfx
