Component: Air Quality (BME688) (Environmental)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author MatrixTSL
Category Environmental
Air Quality (BME688) component
An air quality sensor connected using a standard I2C bus. Capable of detecting indoor and outdoor air quality including CO2 H2 VOCs and VSCs.
Please click here to download the component source project: FC_Comp_Source_BME688_AirQualitySensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BME688_AirQualitySensor.fcfx
Initialises the I2C bus and sets up the device ready for operation. Returns 1 if the device has been found and is communicating.
- BOOL Return
PerformGasResistanceCycle
Performs a forced heating cycle. Returns 1 for a successful cycle. Returns 0 if the heating time was not enough or the temperature was too high to reach.
- FLOAT Temperature
Temperature in Celcius we want to reach, typically between 200 and 400�C
- UINT Duration
Step duration in milliseconds, default 30 - Range: 1 to 4032
- BOOL Return
ReadGasResistance
ReadGasResistance
Reads the resistance of the gas in ohms from the last heating cycle.
- FLOAT Return
ReadHumidity
ReadHumidity
Collects the humidity and returns as a floating point value in percent.
- BYTE Index
Forced Mode = 0 / Parallel Mode = 0-2
- FLOAT Return
ReadPressure
ReadPressure
Collects the pressure and returns as a floating point value in pascal.
- BYTE Index
- FLOAT Return
ReadRegister
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
ReadTemperature
ReadTemperature
Collects the temperature and returns as a floating point value in degrees C.
- BYTE Index
- FLOAT Return
SetMode
SetMode
Sets the mode of the sensor to low power sleep, forced or parallel
- BYTE Mode
0=Sleep, 1=Forced, 2=Parallel
WriteRegister
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
I2C Properties
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Options
Device Address
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
Comms Simulation
Injector
