Component: LIN Slave (Comms)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category Comms
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
Please click here to download the component source project: FC_Comp_Source_LinSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LinSlave.fcfx
GetState
GetState
Returns the state of the device
Initialize
Initialize
Initialises the device
ListenForMessages
ListenForMessages
Listens for messages with Timeout and returns the state
- BYTE Timeout
- BYTE ChecksumType
0=Classic, 1=Enhanced
PowerDown
PowerDown
Power Down the device
ReadAddress
ReadAddress
Returns the Identifier read
ReadData
ReadData
Returns the message data byte
- BYTE Message
Message to be read
- BYTE Index
Index of data byte to be returned
ReadDataCount
ReadDataCount
Return the data count size for Message
- BYTE Message
SetData
SetData
Set the Message data to be automatically sent as part of the ListenForMessages macro.
- BYTE Message
Message to assign data for Range: 1-8
- BYTE Data1
Data byte value
- BYTE Data2
Data byte value
- BYTE Data3
Data byte value
- BYTE Data4
Data byte value
- BYTE Data5
Data byte value
- BYTE Data6
Data byte value
- BYTE Data7
Data byte value
- BYTE Data8
Data byte value
WakeUp
WakeUp
Wake Up the device
TX pin
LIN bus data transmit pin
RX pin
LIN bus data receive pin
CS pin
LIN bus chip select pin
FAULT pin
LIN bus fault detection pin
VREG pin
LIN bus voltage regulation pin
MESSAGES
Number of messages the firmware is designed to listen for
MESSAGE1
ID
Message identifier to listen for
BYTES
Number of bytes to expent in the packet
TX_RX
Data direction for packet
A text label to aid identifying the component.
Timing Adjustments
Timer Adjust TX
Timer Adjust RX
