Component: WLAN (ESP32) (Comms: Networking)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Matrix Ltd.
Version 2.4
Category Comms: Networking
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
Weather Predictor
Here is an example of a next-day weather predictor that also shows the current-day weather for a ESP32 embedded device
It uses the BBC weather component via Netwoekcomms and WLAN ESP32 components to connect to the BBC server and retrieve the weather forecast for the specified area code.
ESP32 weather predictor
User Configurable Network Details
When creating a product using an ESP32 device it is important that it can connect to the network of the person buying the product.
This is complicated as the ESP32 requires that the network SSID and password be defined by the user and this requires a means of getting the data into the ESP32 device.
Luckily as the ESP32 features the ability to host it's own network we can use this to create a simple web interface where the user can enter their network details.
ESP32 Config WIFI
More info on this available here Flowcode Forums - User Configurable Network Details
AcceptClose
AcceptClose
Close the socket associated with the Accepted incoming connection
AcceptOpen
AcceptOpen
Returns 1 if there is an incoming connection on the listening port
ConnectToSSID
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING SSID
- STRING Key
- BYTE Timeout
Number of seconds to wait for the connection, default 20
CreateAccessPoint
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING SSID
Name of the wireless network to create
- STRING Password
Password used to gain access to the network
- BYTE Channel
802.11 Channel Range 1-14
- BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Disconnect
Disconnect
Attempts to disconnect from the SSID.
Initialise the WiFi system Returns 1 if successful Returns 0 if not
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
SSID Index
ReadIP
ReadIP
Collects a single byte from the local IP address. For example 192.168.0.1 Index = 3 : Return = 192 / Index = 0 : Return = 1
- BYTE Index
Range: 0 to 3 Where 3 = the first number and 0 = the last number
ReadIPString
ReadIPString
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1"
- STRING Return
ReadSSIDFromScan
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE Index
SSID Index
- STRING Return
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE Index
SSID Index
- INT Return
ScanForSSID
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SocketClose
SocketClose
SocketConnect
SocketConnect
- STRING Address
- UINT Port
SocketListen
SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT Port
SocketOpen
SocketOpen
Returns 1 if socket sucessfully opened
SocketRead
SocketRead
- STRING Buffer
- UINT Size
SocketWrite
SocketWrite
- STRING Buffer
- UINT Size
Uninitialise
Uninitialise
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not
Verbose Debug
Provides verbose debugging output via hardware UART channel 1 which is often connected to a UART to USB bridge.
SSID Scan Size
Maximum number of SSIDs that can be detailed from a single SSID network scan. Default 8
Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Generate Console Data
