Component: Timer (Timing)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 14.0
Category Timing
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Version information
14, 14.0, 10-07-24, MW, Fixed a bug to reset simulation timer value when TimerReset() is called
18, 14.0, 07-02-25, BR, Hidden Postscaler property as it will cause issues with reported timings if used
19, 14.0, 07-02-25, BR, Changed default to TMR0 with 1:1 prescaler
20, 14.0, 07-02-25, BR, Added timer resolution property to show what resolution of timings can be acheived
21, 14.0, 07-02-25, BR, Hidden some of the less useful properties from the user
22, 14.0, 07-02-25, BR, Fixed a bug where the timer wouldn't correctly report the time when stopped
Here is a basic example showing the operation of the timer component used to time a section of code or the duration of a specific event.
Timer Example
GetCountMicroSeconds
Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond
- ULONG Return
GetCountMilliseconds
Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond
- ULONG Return
GetCountReal
GetCountReal
Returns the count value as a floating point value in seconds.
- FLOAT Return
GetCountSeconds
GetCountSeconds
Returns the count value as a number of whole seconds, rounded down to the nearest second
- ULONG Return
GetCountString
GetCountString
Returns the count value as a floating point string in seconds.
- BYTE Precision
Number of decimal places to display in string
- STRING Return
GetRawCount
GetRawCount
Efficient command to collect the integer number of instructions since the timer was started.
- ULONG Return
ResetCounter
ResetCounter
StartCounter
StartCounter
Starts the timer counting.
- BOOL ResetCounters
Range: 0-1 where 0=Do Not Reset and 1=Reset
StopCounter
StopCounter
Stops the timer counting.
Timer
Timer Peripheral to use to monitor the passage of time.
Prescaler
Bit Depth
Number of bits in the timer peripheral. 8-bit timers can count from 0-255 before overflowing. 16-bit timers can count from 0 to 65535 before overflowing.
Instruction Rate
Timer Resolution (ms)
Max Time Measurement (s)
Max time in seconds that we can measure before rolling over and starting again.
Timer Delay (ms)
Number of milliseconds between timer events which increment the simulated timer counter variable. 10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow. Higher delays will yield greater accuracy.
Decimal Points
Please click here to download the component source project: FC_Comp_Source_TimerComponent.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponent.fcfx
