Component: WLAN (ESP-12S) (Comms: Networking)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Matrix Ltd.
Version 8.0
Category Comms: Networking
WLAN (ESP-12S) component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
Version information
8, 8.0, 07-01-25, MW, initialised return value within ControlTCPServer to prevent ESP error
CheckForPageRequests
CheckTCPServerIP
CheckTCPServerIP
Collects the local IP address of the active TCP server.
- STRING Return
ClientConnect
ClientConnect
Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
- BYTE Type
0 = TCP, 1 = UDP
- STRING IPAddress
e.g. "192.168.1.20"
- UINT Port
Remote port number to connect to, HTTP comms = Port 80
ClientSendArray
ClientSendArray
Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser.
- BYTE Data
- UINT NumBytes
ClientSendRequest
ClientSendRequest
Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser.
- STRING Request
e.g. "GET / HTTP/1.0\r\n\r\n"
ConnectToSSID
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING SSID
- STRING Key
- BYTE Timeout
Number of seconds to wait for the connection, default 20
ControlTCPServer
ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
- BYTE Enable
0 = Stop Server, 1 = Start Server
- UINT Port
Server port to listen for incoming TCP/IP data requests
CreateAccessPoint
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING SSID
Name of the wireless network to create
- STRING Password
Password used to gain access to the network
- BYTE Channel
802.11 Channel Range 1-14
- BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
DisconnectFromSSID
DisconnectFromSSID
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK"
EndServerConnection
EndServerConnection
Disconnects from the current active TCP/IP pipe.
GetByteWithTimeout
GetByteWithTimeout
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
GetFirmwareVersion
GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
- STRING Return
GetInValue
GetInValue
- BYTE index
Index of the request paramter, starting at zero Range 0-2
- STRING Return
GetRxArray
GetRxArray
Attempts to receive a number of bytes from the remote connection If nothing is available then waits up to 200 ms for data to become available. Returns the number of bytes received,.
- BYTE Data
Byte array to store the incoming data
- UINT MaxBytes
Maximum number of bytes to try and receive
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
SSID Index
ReadSSIDFromScan
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE Index
SSID Index
- STRING Return
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE Index
SSID Index
- INT Return
ScanForSSID
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SendString
SendString
Sends the given Text with no preappendment. Useful for sending preformatted command strings. Appends a CR to the end of the string if SendCR is greater than 0.
- STRING Text
- BYTE SendCR
Send_Embedded_HTML_Page1
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page4
SetOutValue
SetOutValue
- BYTE index
Range 0-4
- STRING value
WIFI Properties
Receive Buffer Size
Buffer used to store incoming data ready for processing. Default 128 Bytes.
Scan Buffer Size
Buffer used to hold SSID names when performing a SSID network scan. Default 100 Bytes.
Reset Mode
The initialise automatically resets the WIFI module before establishing communications. Software reset uses an AT command to preform the reset Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Command Termination
Older versions of the firmware require \r to terminate a AT command string. Newer versions of the firmware have changed to use \r\n termination.
Baud Options
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Reset
WLAN module reset pin connection
Use Flow Control
HTML Source
Max Web Pages
Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
Number of cycles to try and send / receive a webpage before timing out.
Line Delay
Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Name Page 1
HTML name of webpage 1
HTML Page 1
HTML content for webpage 1
Name Page 2
HTML name of webpage 2
HTML Page 2
HTML content for webpage 2
Name Page 3
HTML name of webpage 3
HTML Page 3
HTML content for webpage 3
Name Page 4
HTML name of webpage 4
HTML Page 4
HTML content for webpage 4
Substitutions
Outgoing
Count
Length 0
Incoming
Count
Length 0
Simulation Method
Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
Decides if simulation TCP data is available via a console tab
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP12S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP12S.fcfx
