Component: Switch User Images (Switch)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 7.0
Category Switch
Switch User Images component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status. The on and off states of the switch are shown using user supplied images allowing customised switches to be created.
Version information
5, 5.0, 23-09-24, MW, Fixed a bug to  make sure switch starts in the off position
5, 5.0, 23-09-24, MW, Added option for simulation only
5, 5.0, 23-09-24, MW, Fixed a bug preventing custom lable posistion from updating on the fly
5, 5.0, 23-09-24, MW, Fixed connection lable so show correct polariy within array
5, 5.0, 15-04-25, MW, Modified switch to show correct value for off when stating and stopping simulation
5, 5.0, 16-04-25, MW, Fixed a bug where Pin x and  y lables remained visisble when supposed to be hidden
5, 5.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size
5, 5.0, 01-05-25, MW, Changed labels so don't interact and change switch state
5, 5.0, 01-05-25, MW, Corrected pin label properties
5, 5.0, 01-05-25, MW, Added option to hide label
5, 5.0, 01-05-25, MW, Fixed SameAsHandle label to update on rename event
6, 0.0, 01-05-25, MW, Changed switch properties to stop greying out
7, 7.0, 10-03-26, ST, Updated for v11.0.1 mouse event change
ReadState
ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
SetState
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilHigh
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
WaitUntilLow
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Function
Simulation Only
Switch Settings
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = Set, Released = Clear 'Active Low' -> Pressed = Clear, Released = Set
Debounce
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Latching
Determines if the simulated switch maintains its state or revers back to the default state when not clicked.
Component Label
Component label position
Label Colour
Show Connection Label
Show Pin Value
Pin label position
Images
Image On
FilenameOn
Image Off
FilenameOff
Please click here to download the component source project: FC_Comp_Source_Switch_User_Images_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_User_Images_2dgi.fcfx
