Component: Scale (DSP Operators)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.1
Category DSP Operators
Scale component
Allows the values in a single buffer to be scaled uniformly. Functions include: Multiply, Divide, LeftShift, RightShift, Float Multiply, Float Divide
Please click here to download the component source project: FC_Comp_Source_DSP_Scale.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Scale.fcfx
Here is an example which demonstrates variable scaling based on an analogue input.
Scale
Here are the traces as seen on the data recorder window.
The RightShift macro is a very efficient means of performing a division but only for values which are a power of 2.
The LeftShift macro is a very efficient means of performing a multiplication but only for values which are a power of 2.
LeftShift(1) = Multiply by 2 / RightShift(1) = Divide by 2
LeftShift(2) = Multiply by 4 / RightShift(2) = Divide by 4
LeftShift(3) = Multiply by 8 / RightShift(3) = Divide by 8
LeftShift(4) = Multiply by 16 / RightShift(4) = Divide by 16
Calculate
Calculate
Performs the selected scaling on a value from the input buffer and passes to the output buffer.
CalculateArray
CalculateArray
Performs the selected scaling on an entire buffer.
SetScalerFloat
SetScalerFloat
Sets the Float scaler to be used when calling the calculate function.
- FLOAT Scaler
SetScalerInteger
SetScalerInteger
Sets the Integer scaler to be used when calling the calculate function.
- INT Scaler
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Scaling
Scale Type
Defines the type of calculation performed on the input buffer to obtain the output value. A left shift is essentially an optimised multiply with the multiplier being the 2^scaler A right shift is essentially an optimised divide with the divider being the 2^scaler
Rollover
Allow the output buffer to rollover. For example 128 * 2 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled. With rollover disabled the output would be set to 255 which is the max representable value.
Initial Integer Scaler
