Component: Injector (AT) (Test Injectors)
Version 1.1
Category Test Injectors
Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
Please click here to download the component source project: FC_Comp_Source_InjectorAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorAT.fcfx
GSM Example File GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
UARTBaud
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
UARTCheckRX
- BYTE Channel
UARTInitialise
UARTInitialise
- BYTE Channel
UARTReceive
UARTReceive
- BYTE Channel
UARTSend
UARTSend
- BYTE Channel
- BYTE Data
AT Injector Settings
Circular Buffer Size
Amount of room in the circular buffers before running out of memory. e.g. max command that can be recorded.
Termination Character
Character that will trigger the AT Injector to automatically switch from recording to repeating.
Show Console
