Component: API (Arduino Uno) (API Slave Devices)
| Version | 2.0 |
API (Arduino Uno) component
Connects to an Arduino Uno running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
The App Developer (Arduino Uno) component allows an Arduino Uno board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
Arduino Uno App Developer Firmware
The COM port to the Arduino hardware is selected via the App Developer_Ard_Uno componennt COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
| App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 |
| Device Port Pin | D0 | D1 | D2 | D3 | D4 | D5 | D6 | D7 | B0 | B1 | B2 | B3 | B4 | B5 | C0 | C1 | C2 | C3 | C4 | C5 |
| Arduino Style Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | A0 | A1 | A2 | A3 | A4 | A5 |
| App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 |
| Device Port Pin | C0 | C1 | C2 | C3 | C4 | C5 |
| Arduino Style Pin | A0 | A1 | A2 | A3 | A4 | A5 |
| App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | OneWire | Servo 0 | Servo 1 | Servo 2 | Servo 3 | Servo 4 | Servo 5 | Servo 6 | Servo 7 |
| Device Port Pin | C4 | C5 | B3 | B4 | B5 | D6 | D5 | B1 | B2 | B3 | D3 | D2 | D2 | D3 | D4 | D5 | D6 | D7 | D8 | D9 |
| Arduino Style Pin | A4 | A5 | 11 | 12 | 13 | 6 | 5 | 9 | 10 | 11 | 3 | 2 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
ADCSample10
| ADCSample10 | |
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
ADCSample8
| ADCSample8 | |
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-5 | |
ADCSampleArray10
ADCSampleArray8
ADCSampleAverage10
ADCSampleAverage8
ADCSetPrechargeTime
ADCSetReferenceVoltage
| ADCSetReferenceVoltage | |
| Specified the reference setting for ADC reads. | |
| RefType | |
| 0=AREF, 1=VCC, 3=Internal 1.1V | |
I2CInitialise
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
I2CReceive
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
I2CRestart
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
I2CSend
| I2CSend | |
| Channel | |
| DataOut | |
I2CStart
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
I2CStop
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
I2CTransInit
I2CTransReceive
I2CTransSend
IOGetInputPin
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
IOSetOutputPin
| IOSetOutputPin | |
| Pin | |
| Range: 0-19 | |
| State | |
| Range: 0-1 | |
OneWireBusReset
OneWireGetDeviceCount
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
OneWireGetIDByte
OneWireInitialise
| OneWireInitialise | |
| Initialise the OneWire module ready for communications | |
| Channel | |
OneWireMatchROM
OneWireReceiveByte
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
OneWireScanBus
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
OneWireSkipROM
| OneWireSkipROM | |
| Performs a bus reset and the sends the SkipROM command byte | |
| Channel | |
OneWireTransmitByte
| OneWireTransmitByte | |
| Transmit a byte to the one wire bus a bit at a time | |
| Channel | |
| Data | |
PWMDisable
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-5 | |
PWMEnable
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-5 | |
PWMSetDuty
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Duty | |
PWMSetPrescaler
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Prescaler | |
| Period | |
| Default 255 | |
RegisterRead
| RegisterRead | |
| Read one of the registers on-board the device | |
| RegisterAddress | |
| The address of the register | |
RegisterWrite
| RegisterWrite | |
| Writes to one of the registers on-board the device | |
| RegisterAddress | |
| Data | |
| The data value to assign to the register | |
SPIInitialise
| SPIInitialise | |
| Channel | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
SPITransferTrans
ServoDisable
| ServoDisable | |
| Disable a Servo output Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
ServoEnable
| ServoEnable | |
| Enable a Servo output Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
ServoSetPosition8
| ServoSetPosition8 | |
| Sets the position as an 8-bit value Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
| Position | |
| Range: 0-255 | |
