Component: Bits to Data Queue (DSP Outputs)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Outputs |
Bits to Data Queue component
Allows data to be input a bit at a time from the DSP system and passed into a buffer. Useful for things like communications where data is modulated and sent out a bit at a time.
Please click here to download the component source project: FC_Comp_Source_DSP_BitsToData.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_BitsToData.fcfx
CollectNextDataBit
| CollectNextDataBit | |
| Gets the next value from the DSP buffer and attempt to add as a bit to the data queue. | |
CountQueueData
| CountQueueData | |
| Returns the number of data bytes received and stored in the queue. | |
GetByte
| GetByte | |
| Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
GetByteArray
| GetByteArray | |
| Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
GetFloat
| GetFloat | |
| Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
GetFloatArray
| GetFloatArray | |
| Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
GetInt
| GetInt | |
| Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
GetIntArray
| GetIntArray | |
| Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
GetLong
| GetLong | |
| Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
GetLongArray
| GetLongArray | |
| Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
| Data | |
| Count | |
GetString
| GetString | |
| Collects a string from the receive buffer. | |
| MaxLength | |
| Maximum number of characters to try and receive | |
