Component: I2C Slave (Comms: Interface)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author Matrix Ltd.
Version 1.3
Category Comms: Interface
I2C Slave component
Please click here to download the component source project: FC_Comp_Source_I2C_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Slave.fcfx
Check_Status
Check_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
ReceiveByte
ReceiveByte
Receives a byte from the I²C bus. Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE Last
Used to signify the last byte when streaming incoming data. 0=Not last byte, 1=Last Byte
TransmitByte
TransmitByte
Sends a byte on the I²C bus. Returns the acknowledge if any. 0 represents that data was acknowledged and 1 represents no acknowledge was detected.
- BYTE Data
Data byte to send on the I²C bus.
Bus Settings
Channel selection
Baud Select
Baud rate to be used
Stop Delay
Slave Setttings
Slave Address
Mask
0 - don't care; 1 - perform match; So address of 0x30 and mask of 0xF0 will allow the slave to respond to addresses of 0x30, 0x31, 0x32, …, 0x3F
SDA
SCL
Label shown on the comms flasher on the simulation panel.
API
