Component: Colour Sensor (Grove 101020341) (101020341) (Light)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 8.0
Category Light
Colour Sensor (Grove 101020341) component
Based on the color sensor TCS34725FN with digital output I2C. Based on the 8*2 array of filtered photodiodes and 16-bits analog-to-digital converters, you can gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input pin, external pulsed light source can provides precise synchronous conversion control.
Version information
8, 0.0, 27-06-25, MW, Not working on ESP32, changed I2C to transaction functions
CalculateLux
CalculateLux
Uses the RGB values stored in RAM from the last Sample to calculate the luminance in lux.
CalculateTemp
CalculateTemp
Uses the RGB values stored in RAM from the last Sample to calculate the colour temperature in degrees Kelvin.
ClearInterrupt
ClearInterrupt
Clears the interrupt flag allowing the device to interrupt again.
ControlInterrupt
ControlInterrupt
Enables or Disables the Interrupt pin to fire when the light levels are inside the interrupt limits.
- BYTE Enable
Range: 0 to 1 - 0=Interrupt Off / 1=Interrupt On
- UINT LowLevel
- UINT HighLevel
DisableSensor
DisableSensor
Powers down the device to save power.
EnableSensor
EnableSensor
Powers up the device ready for taking colour readings.
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor.
ReadDataChannel
ReadDataChannel
Returns the value of the selected colour channel from the last sample. The Red, Green and Blue channels have a colour filter to remove light of other colours. The Clear channel has no filter allowing the ambient light level to be easily collected.
- BYTE ColourChannel
Range: 0 to 3 - 0=Red, 1=Green, 2=Blue, 3=Clear
SampleSensor
SampleSensor
Reads the raw colour channels from the sensor and stores the readings into RAM to be collected by the ReadDataChannel macro.
SetGain
SetGain
Controls the gain. 0x00 = 1X 0x01 = 4X 0x02 = 16X 0x03 = 60X
- BYTE Setting
Range: 0 to 3
SetIntegrationTime
SetIntegrationTime
Controls the integration time. 0 = 700mS / 1 = 154mS / 2 = 101mS / 3 = 50mS / 4 = 24mS / 5 = 2.4mS
- BYTE Setting
Range: 0 to 5
Sensor Settings
Integration Time
Length of time period used to sample the sensor frequency (longer is more accurate)
Gain
Channel selection
Mode
Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Simulation Type
Selects the simulation type for the component. Component GUI - Interacts with the panel to sense the colour of a object in close proximity to the sensor. I2C Injector - Performs the I2C commands allowing you to connect an injector component or view and debug the I2C communications.
Please click here to download the component source project: FC_Comp_Source_Colour_Sensor_I2C_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Colour_Sensor_I2C_Grove.fcfx
