Component: API (Arduino Uno) (API Slave Devices)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 2.0
Category API Slave Devices
API (Arduino Uno) component
Connects to an Arduino Uno running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Arduino_Uno_API_Comp.fcfx
The App Developer (Arduino Uno) component allows an Arduino Uno board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
Arduino Uno App Developer Firmware
The COM port to the Arduino hardware is selected via the App Developer_Ard_Uno componennt COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
Device Port Pin D0 D1 D2 D3 D4 D5 D6 D7 B0 B1 B2 B3 B4 B5 C0 C1 C2 C3 C4 C5
Arduino Style Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 A0 A1 A2 A3 A4 A5
App Developer Slave Analogue Pin 0 1 2 3 4 5
Device Port Pin C0 C1 C2 C3 C4 C5
Arduino Style Pin A0 A1 A2 A3 A4 A5
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 OneWire Servo 0 Servo 1 Servo 2 Servo 3 Servo 4 Servo 5 Servo 6 Servo 7
Device Port Pin C4 C5 B3 B4 B5 D6 D5 B1 B2 B3 D3 D2 D2 D3 D4 D5 D6 D7 D8 D9
Arduino Style Pin A4 A5 11 12 13 6 5 9 10 11 3 2 2 3 4 5 6 7 8 9
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
Simple Arduino Uno Demo
ADCSample10
ADCSample10
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
ADCSample8
ADCSample8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-5
ADCSampleArray10
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleArray8
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
ADCSampleAverage8
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
ADCSetPrechargeTime
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
I2CInitialise
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
I2CReceive
- BYTE Channel
- BOOL Last
I2CRestart
I2CRestart
- BYTE Channel
I2CSend
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
I2CStart
I2CStart
- BYTE Channel
I2CStop
I2CStop
- BYTE Channel
I2CTransInit
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
I2CTransReceive
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
I2CTransSend
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-19
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-19
- BOOL State
Range: 0-1
OneWireBusReset
OneWireBusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BYTE Channel
- BOOL Return
OneWireGetDeviceCount
- BYTE Channel
OneWireGetIDByte
OneWireGetIDByte
Returns a single byte of the 64-Bit lasered ROM code, 255 on error
- BYTE Channel
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
OneWireInitialise
OneWireInitialise
Initialise the OneWire module ready for communications
- BYTE Channel
OneWireMatchROM
OneWireMatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE Channel
- BYTE FamilyCode
- BYTE SerialNumber
OneWireReceiveByte
OneWireReceiveByte
- BYTE Channel
OneWireScanBus
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
OneWireSkipROM
OneWireSkipROM
Performs a bus reset and the sends the SkipROM command byte
- BYTE Channel
OneWireTransmitByte
OneWireTransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Channel
- BYTE Data
PWMDisable
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-5
PWMEnable
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-5
PWMSetDuty
PWMSetDuty
- BYTE Channel
Range: 0-5
- BYTE Duty
PWMSetPrescaler
PWMSetPrescaler
- BYTE Channel
Range: 0-5
- BYTE Prescaler
- BYTE Period
Default 255
RegisterRead
RegisterRead
Read one of the registers on-board the device
- UINT RegisterAddress
The address of the register
RegisterWrite
RegisterWrite
Writes to one of the registers on-board the device
- BYTE Data
The data value to assign to the register
SPIInitialise
SPIInitialise
- BYTE Channel
SPIPrescaler
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
SPITransfer
SPITransfer
- BYTE Channel
- BYTE DataOut
SPITransferTrans
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
ServoDisable
ServoDisable
Disable a Servo output Ch0 to 7 = Pins 2 to 9
- BYTE Channel
Range: 0-7
ServoEnable
ServoEnable
Enable a Servo output Ch0 to 7 = Pins 2 to 9
- BYTE Channel
Range: 0-7
ServoSetPosition8
ServoSetPosition8
Sets the position as an 8-bit value Ch0 to 7 = Pins 2 to 9
- BYTE Channel
Range: 0-7
- BYTE Position
Range: 0-255
Connection
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
OneWire
SERVO
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
