Component: Speech (Phoneme) (Audio Output)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.2
Category Audio Output
Speech (Phoneme) component
Speech component allowing Phoneme based speech for use on an embedded platform. The simulation also has an advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine.
Example of Phoneme Speech (download and simulation) Speech The Phoneme based speech can be output on Microcontroller hardware using a number of methods.
PWM - Outputs using a single PWM pin, a simple external RC low pass filter can be used to remove the high frequency PWM to create an audio signal.
Parallel - Outputs using a 8-bit port, a simple 8-bit R2R DAC circuit can be used to combine the bits into an audio signal.
Other - A third option is to use the ReadByteFromPhoneme macro to pull out the phoneme values a byte at a time which can be used to pass on to an external DAC etc.
Another example of Phoneme Speech, taking a reading from an analogue channel and speaking the Voltage. (download and simulation) Talking Volt Meter
DisableOutput
DisableOutput
Disables the output to prevent any buzzing etc while not speaking.
EnableOutput
EnableOutput
Sets up the output to allow the speech data to be streamed out.
Ev_Start
Ev_Start
Broadcast to all components that simulation is starting
- ULONG Return
OutputPhoneme
OutputPhoneme
Streams a single Phoneme or string of comma seperated Phonemes. OutputPhoneme("OY") OutputPhoneme("OY,AY,OY")
- STRING DataString
ReadByteFromPhoneme
ReadByteFromPhoneme
Reads a single byte value from the specified phoneme data array. This function will not simulate correctly as it requires C style pointers.
- STRING Phoneme
Specifies a single Phoneme
- UINT Idx
Specifies the position within the Phoneme
ReadPhonemeLength
ReadPhonemeLength
Function to return the number of bytes used in a single phoneme array.
- STRING Phoneme
Phoneme Settings
Phoneme Selection
Selects which phonemes are included in the embedded firmware
Phoneme Data Set
Specifies if the phonemes used are based on the inbuilt phoneme wav files set or a custom file set. To create your own phonemes, copy the wav files from the components directory, then overwrite the phonemes you wish to edit. Phonemes are re-parsed on simulation start and on compile to C.
Pitch (Hz)
The frequency at which the phoneme data is output in bytes/samples per second.
Phoneme Data Size
The number of bytes used by the current phoneme selection
ROM Size
The maximum number of bytes available in the ROM of the selected target device. The ROM has to contain the program as well as the Phoneme data.
Base ROM Address
The address in ROM to place the phoneme data. It is recomended to always use the suggested address as this will place the phonemes right at the end of ROM and away from the program.
Suggested Address
The ideal address to allow all the selected phonemes to fit into the end of the ROM memory Thereby allowing the maximum space for the user program.
Output Mode
Determines how the phoneme data is going to be output.
PWM Pin
PWM channel selection used to determine which PWM peripheral to stream the Phoneme data to.
PWM Pin
The actual port pin assigned to the selected PWM channel.
Phoneme Selection
Select All
Selects all Phonemes
Select None
Deselects all Phonemes
PA1 (10ms)
10ms Pause - Always included
PA2 (30ms)
30ms Pause - Always included
PA3 (50ms)
50ms Pause - Always included
PA4 (100ms)
100ms Pause - Always included
PA5 (200ms)
200ms Pause - Always included
AA - hOt
Phoneme selection
AE - hAt
Phoneme selection
AO - AUght
Phoneme selection
AR - alARm
Phoneme selection
AW - sOUnd
Phoneme selection
AX - Apple
Phoneme selection
AY - skY
Phoneme selection
BB1 - Brown
Phoneme selection
BB2 - Business
Phoneme selection
CH - CHurCH
Phoneme selection
DD1 - enD
Phoneme selection
DD2 - Down
Phoneme selection
DH1 - THey
Phoneme selection
DH2 - baTHe
Phoneme selection
EH - Extent
Phoneme selection
EL - angLE
Phoneme selection
ER1 - intERupt
Phoneme selection
ER2 - bIRd
Phoneme selection
EY - grEAt
Phoneme selection
FF - Food
Phoneme selection
GG1 - Get
Phoneme selection
GG2 - Green
Phoneme selection
GG3 - anGer
Phoneme selection
HH1 - Help
Phoneme selection
HH2 - Hope
Phoneme selection
IH - sIt
Phoneme selection
IY - trEAt
Phoneme selection
JH - inJure
Phoneme selection
KK1 - Clown
Phoneme selection
KK2 - tasK
Phoneme selection
KK3 - Crane
Phoneme selection
LL - Lake
Phoneme selection
MM - Milk
Phoneme selection
NG - aNGer
Phoneme selection
NN1 - thiN
Phoneme selection
NN2 - Now
Phoneme selection
OR - stORe
Phoneme selection
OW - zOne
Phoneme selection
OY - nOIse
Phoneme selection
PP - triP
Phoneme selection
RR1 - WRite
Phoneme selection
RR2 - gRease
Phoneme selection
SH - SHip
Phoneme selection
SS - teSt
Phoneme selection
TH - THin
Phoneme selection
TT1 - tesT
Phoneme selection
TT2 - Test
Phoneme selection
UH - bOOk
Phoneme selection
UW1 - cumpUter
Phoneme selection
UW2 - fOOd
Phoneme selection
VV - Vest
Phoneme selection
WH - WHite
Phoneme selection
WW - Work
Phoneme selection
XR - haiR
Phoneme selection
YR - clEAR
Phoneme selection
YY1 - compUter
Phoneme selection
YY2 - Yes
Phoneme selection
ZH - aZure
Phoneme selection
ZZ - phaSe
Phoneme selection
Please click here to download the component source project: FC_Comp_Source_speech.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_speech.fcfx
