Component: Switch (Toggle, PCB) ()
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
Please click here to download the component source project: FC_Comp_Source_sw_toggle_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_pcb.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Connection
Chip pin to which this switch is connected.
Polarity
Sets whether the pin should go high or low when the switch is activated.
Debounce (ms)
Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state with the component macros. Chip pin is NOT debounced.
Operation
Latching - click the switch to turn it on, click again to turn it off. Momentary - click the switch to turn it on, release the mouse to turn it off.
