Exporting a Macro
Revision as of 15:24, 21 May 2013 by ReeceL (talk | contribs) (ReeceL moved page Exporting A Macro to Exporting a Macro without leaving a redirect)
<img>
Macros you create can be exported to a file for later use. Select the Export option from the Macro menu. Flowcode will first ask you to select the macro you wish to export and then ask you for a filename. Flowcode macros are exported with the file extension .FCM
If the Read Only tick box is ticked then the exported macro will be locked making the macro unable to be edited when importing back into other Flowcode programs.
