API File.Buffer.Create
wiki page name
File.BufferCreate
Creates the new file as a circular buffer
STRING Filename
- The name of a new file to create
ULONG Bytes
- The number of bytes to fix the buffer to
- The default value for this parameter is: 0x10000
BOOL Write
- Set to enable write access
BOOL Monitor
- Set to enable monitoring of the file
Calling in a calculation:
- Add to a calculation icon: result = ::File.Buffer.Create("filename", bytes, false, true)
