API Component.Property.SetValue
Revision as of 19:56, 7 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Sets a components property as a string
Class hierarchy
Component
Property
SetValue
HANDLE Handle
The component handle of the property owner
STRING Property
The textual name of the property
STRING Value
The value to update the property text with
This sets the internal value of a property, and compliments GetValue.
Note this call does not set the value the property will evaluate to, but sets the value that will be evaluated.
For example, a port connection property may be set to the string "$PORTA", but this call can not be used to change the value of a port.
When code is generated the value of the property becomes fixed for the generated code corresponding to the last call to SetValue().
  • Add to a calculation icon:
    ::Component.Property.SetValue(handle, "property", "value")
