API Panel.Position.RotateTo
Revision as of 21:51, 12 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Rotates the object to the given rotation
Class hierarchy
Panel
Position
RotateTo
HANDLE Handle
HANDLE Pivot
The coordinates of the rotation center, Handle if zero
HANDLE Axis
An axis to align the angles to, Handle if zero
FLOAT X_Pitch
The absolute local X degrees to update with
FLOAT Y_Yaw
The absolute local Y degrees to update with
FLOAT Z_Roll
The absolute local Z degrees to update with
  • Add to a calculation icon:
    ::Panel.Position.RotateTo(handle, pivot, axis, x_pitch, y_yaw, z_roll)
