Event class Components
Revision as of 00:50, 12 May 2013 by Admin (talk | contribs) (XML import)
See the individual events for details of how to use this event class
Events provided for this class
Property Sent when a property has been changed by the User
Added Broadcast to all existing components once a new component has been added
Adding Broadcast to all existing components when a new component is about to be added
Resize Sent to the mouse target when the user has altered the position of a component child
Removed Broadcast to all remaining components once an existing component has been removed
Removing Broadcast to all existing components when an existing component is about to be removed
Closedown Closedown routine for the component
Closing Pre-Closedown routine for the component, sent when the component is linked
Initialise Initialisation routine for the component once the component is linked to its parent
Initialising Initialisation routine before the component is linked to its parent
See also
