API Sound.Queue
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Queues a sound for playing
Class hierarchy
Sound
Queue
HANDLE Sounds
The handle of the sound object to queue to
ARRAY Data
The array to play data from
ULONG Offset
The element in the array to start at
ULONG Elements
The number of elements to play
The default value for this parameter is: -1
FLOAT RateMul
A multiplier to the sounds sample rate
The default value for this parameter is: 1
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Sound.Queue(sounds, _arraydata, offset, elements, ratemul)
