API Component.Clone
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Clones an existing object to another position on the panel
Class hierarchy
Component
Clone
HANDLE Source
The object to copy
HANDLE DestParent
The parent to link the cloned object to
HANDLE NewPosition
A position to move the object to
HANDLE
A handle to the newly created component, 0 if the call failed.
This creates an identical copy of the object which may be inserted at any point in the component tree.
The root object may not be cloned, but other to that any object (even a definition) may be cloned.
  • Add to a calculation icon:
    result = ::Component.Clone(source, destparent, newposition)
