API File.NVM.WriteArray
Revision as of 09:58, 17 June 2013 by JonnyW (talk | contribs) (XML import of updated API docs)
<sidebar>API contents</sidebar> Writes an array to the NVM
Class hierarchy
File
NVM
WriteArray
HANDLE FileHandle
The handle of an open file
ULONG Address
Position in the file in bytes
ARRAY Data
Array of data to write to the file
ULONG Elements
Maximum number of elements to write
The default value for this parameter is: -1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.NVM.WriteArray(filehandle, address, _arraydata, elements)
