API Console.AddMemory
<sidebar>API Contents</sidebar> Adds a window to the list of consoles available
Class hierarchy
Console
AddMemory
STRING Name
The name to appear as the consoles title
ULONG Bytes
The number of bytes to add to the buffer
ULONG BpL
The number of bytes per line to display
The default value for this parameter is: 16
BYTE Init
The value to initialise each byte of memory to
BOOL UserWrite
Set true to allow amending of the data from the User
HANDLE
A handle to the memory console that can be used to change its style and content.
A memory console is a block of text suitable for use as a memory display, for example to display the contents of a disk or EEPROM. When text is added, this will always overwrite the existing memory so the text contents will remain the same size. This differs from the AddText call which has an unlimited size and operates in 'append' mode to add to the text.
Once a handle is created it must be retained, as Flowcode will remove any handles from the system that are not referenced.
The style and content of the console can be changed at any time. The only thing that is fixed is the type of console - a memory console always has a fixed size and a fixed number of characters per line.
  • Add to a calculation icon:
    result = ::Console.AddMemory("name", bytes, bpl, init, false)
Flowchart example
The example File:SIMAPI Console.fcfx illustrates basic creation of a console window.
