Analog Window
Revision as of 10:15, 23 September 2013 by ReeceL (talk | contribs)
The Analog Window displays and monitors analog values on each channel, allowing you to see the results/values of each channel both as a text values and dynamic bars to display the output values of analog devices.
To open the 'Analog Window' select 'Analog Inputs' from the 'View' menu (View > Analog Inputs').
You can change the 'View values as:' option at the top of the window by selecting an option from the drop-down box, by doing so you can change the text to display the data value of the analog channels as:
  • Raw
  • Byte
  • Percent
  • Unit
