Using the Data Console
Revision as of 15:39, 31 October 2013 by Admin (talk | contribs)
<sidebar>Sidebar: What Is a Component?</sidebar>
The Data Console allows the user to monitor raw data and display the process of a component fucnction and even the progress of the flowchart by writing to the console using Simulation Macros to send / write data to the console.
The console has many macros and functions for effective use in simulation, text and data can be displayed on the console from raw data to variable values and even manually inputted text strings.
Text can be inputted before or after data from variables or other sources, for example, you can write text to the console before a variable value to name or label the data, you can also write text after the variable to display a value or unit after the data e.g. Volume = 10dB, Speed = 25mph etc. (text before variable value text after) this can be done using only 3 Simulation Macro icons.
The Data Console can be used for creating counters, trackers and monitoring information etc. this information is displayed in the console to present relevant information and data to clarify the process of the program and is especially useful for demonstrating the program.
Creating a new console tab
To create a new console tab you first need to create a global handle type variable to store the reference to the console window. This is basically a unique number which used to refer to that specific tab of the console window. To do this open the [Project_Explorer|Project Explorer] window and select the Globals tab.
The output and input text colour can be changed using the SetOutputRGB and SetInputRGB simulation functions, to do so you must enter the required parameters; a Handle value for the ConsoleHandle parameter and a ULONG value for the RGB parameter. This can be changed multiple times so specific text and data can be a different colour to highlight important or relevant information.
