API File.NVM.WriteByte
Revision as of 15:35, 10 May 2013 by Admin (talk | contribs) (XML import of API auto-gen)
<sidebar>API contents</sidebar> Writes a single byte to the NVM multiple times
HANDLE FileHandle
The handle of an open file
ULONG Address
Position in the file in bytes
BYTE Data
Array of data to write to the file
BYTE Count
Number of times to write the byte in sequence
The default value for this parameter is: 1
ULONG
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.NVM.WriteByte(filehandle, address, data, count)
