API Component.Property.SetListItem
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Sets an existing list entries text for the property by named index
Class hierarchy
Component
Property
SetListItem
HANDLE Handle
The component handle to alter the property of
STRING Property
The textual name of the property
STRING Index
The text or integer entry of the property
STRING Value
The value to update the entry with
BOOL
Returns true if the operation is a success, else false
Sets the text part of a list property identified by its 3-digit Index'. If the line does not exist this call fails.
Note the Index is not the line of the list to extract, but the 3-digit identifier. If multiple lines have the same identifier this will extract the first found.
To find the index from the line, use GetListIndex.
To add the line to the list regardless of whether it exists, use AddListItem.
  • Add to a calculation icon:
    result = ::Component.Property.SetListItem(handle, "property", "index", "value")
