API FCD.GetPathHandle
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Gets a FCD paths handle, suitable for traversal with the Tree API
Class hierarchy
FCD
GetPathHandle
STRING PathName
The '.' separated path through the FCD to look in
HANDLE StartPoint
The handle of an existing FCD path to start the search
HANDLE
Returns the FCD paths handle, suitable for traversal with the Tree API
This will get a handle suitable for traversal by the Tree API which is a collection of functions suitable for traversing the FCD files.
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attributes are located. So to extract a handle to the FLASH memory detailes Pathname="device.memory".
If the StartPoint is provided then it is assumed this is a handle to a previous call to GetPathHandle, and this path is prepended to PathName. So if StartPoint is a handle to "device.configuration" and PathName="settings.setting" then the full path found will be "device.configuration.settings.setting".
  • Add to a calculation icon:
    result = ::FCD.GetPathHandle("pathname", startpoint)
