API Panel.PCloud.SetGridFlat
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Sets the X,Y,Z point lists in a flat height-map grid
Class hierarchy
Panel
PCloud
SetGridFlat
HANDLE PCloud
The handle to the cloud set the points of
FLOAT[] Origin
An (X,Y,Z) array to use as an offset for the generated grid
FLOAT[] XStep
An (X,Y,Z) array to increment the point for each X of the grid
FLOAT[] YStep
An (X,Y,Z) array to increment the point for each Y of the grid
ULONG GridWidth
The X elements of the grid to calculate
ULONG GridHeight
The Y elements of the grid to calculate
  • Add to a calculation icon:
    ::Panel.PCloud.SetGridFlat(pcloud, _arrayorigin, _arrayxstep, _arrayystep, gridwidth, gridheight)
