API Scope.AddPort
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Adds an input to the stream from a port
Class hierarchy
Scope
AddPort
HANDLE StreamH
A handle to a previously created datascope stream
ULONG PortIndex
A zero-based port index, or a textual port name
ULONG BitMask
The bits of the port to isolate and use
The default value for this parameter is: -1
BOOL PackMask
True to pack all the bits together, false to leave gaps
The default value for this parameter is: 1
BOOL Merge
True to bitwise-or the bits with the current data, false to append to the end
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Scope.AddPort(streamh, portindex, bitmask, true, false)
