API System.WDTEnable
Revision as of 15:58, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Enables or disables the software watchdog during long operations
Class hierarchy
System
WDTEnable
BOOL Enable
Set true to enable, false to disable
This disables the software watchdog timer (SWWDT) for long operations, preventing the 'An operation is taking a long time to complete' message from popping up if an algorithm takes a long time.
Note this call will only take effect inside an event, and the results will only be applicable for the duration of that event. This means a component can not permanently disable the watchdog.
Nevertheless, for clean usage a flowchart should always re-enable the SWWDT with Enable set to true for every disable call made. This call may be nested and a disable count is maintained.
  • Add to a calculation icon:
    ::System.WDTEnable(false)
