API Panel.Position.RotateTo
<sidebar>API contents</sidebar> Rotates the object to the given rotation
Class hierarchy
- Panel
- Position
- RotateTo
- Position
HANDLE Handle
HANDLE Pivot
- The coordinates of the rotation center, Handle if zero
HANDLE Axis
- An axis to align the angles to, Handle if zero
FLOAT X_Pitch
- The absolute local X degrees to update with
FLOAT Y_Yaw
- The absolute local Y degrees to update with
FLOAT Z_Roll
- The absolute local Z degrees to update with
- Add to a calculation icon:
::Panel.Position.RotateTo(handle, pivot, axis, x_pitch, y_yaw, z_roll)
