API Panel.Collision
Revision as of 15:12, 11 May 2016 by BenR (talk | contribs)
<sidebar>API Contents</sidebar> Collision detection functions
This class is contained within Panel.
Functions provided for this class
TestTable Tests whether an object collides with the table top, returns Z distance to move to rest on the table
TestSingle Tests whether an object collides with a position
GetSingleAxis Tests whether an object collides with a position
GetSinglePos Returns the position to move Pos to so it does not collide with Test - null if no collide
GetMultiAxis Tests whether an object collides with a position
GetMultiPos Returns the position to move Pos to so it does not collide with any other object - null if no collide
Detecting Collisions
Simple example showing how to detect for collisions between objects on the panel. An object moves back and forth between two fixed objects. Each time the moving object hits a static object it will change it's direction.
Collide
See also
