Component: MIAC GSM (MIAC: Addon Modules)
| Version | 1.0 (Release) |
| Category | MIAC: Addon Modules |
GSM Addon for MIAC System.
GSM_SetStart
Sets the state of the GSM module Start pin.
(Low level GSM interface)
- BYTE State
GSM_CheckNetworkStatus
Returns the state of the GSM network.
0 = Not connected, 1 = connected, 255 = no reply from GSM.
GSM_SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
- <- STRING Command
- BYTE SendCR
GSM_SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
GSM_SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol.
Returns 0 for success and 255 for failure.
- <- STRING Number
- <- STRING Message
GSM_GetCharCount
Returns the number of characters waiting to be read from the receive buffer.
GSM_CheckForIncoming
Checks to see if any incoming phone call or SMS message.
0 = Nothing, 1 = Text Received, 2 = Phone Ringing
GSM_HangUpCall
Ends a voice based call.
GSM_SetReset
Sets the state of the GSM module Reset pin.
State = 0 will hold the module in the reset state
- BYTE State
GSM_DialNumber
Performs a standard voice call by dialling the number specified.
Returns 0 for call in progress and 255 for no response.
- <- STRING Number
GSM_StringReceive
Attempts to receive a string from the GSM modem.
Returns 1 if successful, 0 on timeout
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
GSM_AnswerIncomingCall
Answers the phone for an incoming type call.
GSM_SetRTS
Sets the state of the GSM module RTS pin.
- BYTE State
GSM_Initialize
Resets and restarts the GSM module
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
GSM_SendCharacter
Sends the byte character to the GSM module.
- BYTE Byte
GSM_ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
GSM_GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
GSM_GetStatus
Returns status bits from the GSM module.
Bit 6 = CTS, Bit 12 = STATUS (LED), Bit 13 = RING
AnalogInput
Read the ADC value of a Terminal
Returns 12 bit ADC reading
- BYTE Terminal
- Terminal number to be read
GSM_GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
DigitalInput
Read the value of a terminal
- BYTE Terminal
GSM_GetCharacter
Returns the next character waiting to be read from the receive buffer.
Simulation macro reference
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Maximum number of scripts to store in the device's ROM
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
ASCII based AT command data stored in ROM and used when sending script 1
Expect Echo
This property is of type Fixed list of ints and can be referenced with the variable name expect_echo.
