API Expand.Property
Revision as of 21:24, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Expands a string to the name of a property used in the generated code
===Class hierarchy===Expand
Property
STRING Source
The property name to expand
HANDLE Owner
A component that owns the property
BOOL AddName
Set true to return the name part of the expansion
BOOL AddValue
Set true to return the value part of the expansion
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.Property("source", owner, false, true)
