API File.Buffer.Open
Revision as of 21:25, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Opens the existing file as a circular buffer
===Class hierarchy===File
Buffer
Open
STRING Filename
The name of an existing file to open
BOOL Write
Set to enable write access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
  • Add to a calculation icon:
    result = ::File.Buffer.Open("filename", true, false)
